I want to change the variable of Thing by using the push button.
SH_KIM
Dear all
I'm trying to send an e-mail on mash-up button.
The test was completed using the mail extension.
I want to send mail when the push button of mash up is pressed.
So, when I click the button of the mashup,
I need to activate the bool variable to activated the subscription.
  (Push the button)
 (Change the Set value to true)
Thank you.
SH_KIM
(To:PaiChung)
Hi Paichung,
What I'm asking, how do I trigger bool variable ?
That mean, How can I link the Button and Bool variable.
However, It was solved using Set properties and Get properties values.
Thanks for your reply,
PaiChung
22-Sapphire I
(To:SH_KIM)
Why not trigger the SendMessage service directly?
SH_KIM
(To:PaiChung)
Hi Paichung,
PaiChung
22-Sapphire I
(To:SH_KIM)
Glad you figured it out.
You can even use custom service and use Thing[NameOfThing].NameOfProperty = value;
Or use UpdatePropertyValues if you want to set multiple properties that are local or remote properties.
