I have two IOT devices, Successfully I am able to communicate with my devices. I want to display the devices info & status in UI. I think it's possible to integrate below devices with Thingworx. some one could you guide me for this..
IOT devices:
1) Philips hue bridge
2) XDK sensor gateway (Robert Bosch)
Thank you...
See my suggestions for connecting the Bosch XDK to ThingWorx here.
Here's a Philips edge connector starter kit from the ThingWorx Marketplace you can use to connect to Philips Hue devices.
Hi @tponnuchamy,
Are you able to connect your devices with Thingworx server or you are still facing the issue.
Hi Ravi,
Now i am trying with Hue Bridge. I am not able to start the PhilipsHueAgent.jar file.
Thank you.
There should be a Philips Hue Edge Connector User Guide in the zip archive you downloaded. Make sure you've configured the connector properly, and that you're meeting the requirements. Here are some highlights:
Make sure all of the above is correct. If, "java -jar PhilipsHueAgent.jar", doesn't work after that, please paste the trace from the command window where you run the jar here.
Philps Hue Edge Connector Version 1.0 User Guide has a lot more detail on the items above, as well as setting up your Remote Thing in ThingWorx.
