If I want to Simulate my Cloud Thingworx composer, what should I do?
Benzar
Hi. I'm a student and just started using Thingworx.
I didn't install a local Thingworx,
instead I'm using a cloud version.
The address is https://pp-(some numbers)gg.devportal.ptc.io/Thingworx/Composer/index.html
I have a jar file (a simulation) and the config json looks like this:
"ServerLocation": "",
"Port": 80,
"AppKey": "",
"Security": false,
"RemoteRepo": "/ThingworxRemoteRepository"
 If I wanna use the cloud environment, how should I setup the Json?
Thank you guys.
5 REPLIES 5
dupatel
(To:Benzar)
@Benzar You can try changing JSON config with something as below-
"ServerLocation": "pp-(some numbers)gg.devportal.ptc.io",
"Port": 8443, //need to mention SSL port since Https is used
"AppKey": "XXXX-XXXX-XXXX-XXXX", // should be replaced by actual App key
"Security": true,
 -Durgesh
Benzar
(To:dupatel)
@PaiChung Thanks. I just switched to local installed version.
Benzar
(To:dupatel)
@dupatelThanks for your help :D
PaiChung
22-Sapphire I
(To:Benzar)
"Port": 443,
"AppKey": "YourAppKeyHere",
"Security": true,
 Ok someone already replied, and it may be 8443 vs 443
Also make sure that for your simulator the folder ThingworxRemoteRepository exists. You can specify a more specific path if you need like c:\....
Leigh
Emeritus
(To:Benzar)
Hi @Benzar
Just wanted to follow up to confirm if Durgesh and Pai's responses resolved your question.  If so, please indicate which is your Accepted Solution.  If not, please let us know your current status.
Thanks!
Leigh
