Image to be visible for 5 sec on having "getPropertyValues"
msakshi1
2-Explorer
Is there a way, when i fetch data from edge micro server(EMS) to thingworx using "getPropertyValues" to get an image change.
The moment i get the values in ThingWorx i want an image to appear for 5 sec and then disappear over the mashup.
8 REPLIES 8
nkhose
(To:msakshi1)
Hi
You may try auto-refresh widget set refresh interval 5 Sec , you will need one service which return Bool "False" value ,
Bind the auto-refresh widget refresh event to this service, then bind the service result to image widget visible property Image will display for 5 Sec.
Nilesh
msakshi1
2-Explorer
(To:nkhose)
Thank you, Nilesh
i can try with the method you suggested, just one small question- what is that you want me to write in the service.
I really have very less knowledge about services.
nkhose
(To:msakshi1)
var result=false
output as Boolean
msakshi1
2-Explorer
(To:nkhose)
Thank you so much Nilesh
You don't need autorefresh widget if you are on 7.2 with "Push Properties". On the server you can change a property for 5 seconds ( from false to true ) and bind that property to visibility of the image.
Thanks Carles,
I would love to try your way as well, but i am sorry to say that currently i am woking on Thingworx 6.5 and not 7.2 .
Then you should go for Nilesh Khose​ solution.
Thank you Carles
