I am using a numeric widget to store data in my database but when I enter an underscore in the numeric entry widget it is allowing it. Please check and respond.
Sasi,
Why are you trying to enter an underscore in the numeric entry widget? Is there a use case that you need an underscore with numbers?
Meghan
I am trying to do a validation. If I enter anything except a digit in the numeric widget it should throw an error. I wrote java script for that and If i use the base type as string it will work but when i choose a number it does not work. Since numeric entry widget doesn't allow any other special characters. Why is it allowing underscore?
Java 8 allows underscores in numbers to make them more readable. I'd guess the widget is following suit e.g.
100_000_000 is the same as 100000000
Except that Thingworx itself doesn't process it that way, right now Thingworx will read 1_000 as 1 vs. 1000
Well, it was a guess
