In the numeric entry widget underscore is allowed. Why this is happening?
snatarajan-2
6-Contributor
I am using a numeric widget to store data in my database but when I enter an underscore in the numeric entry widget it is allowing it. Please check and respond.
5 REPLIES 5
Sasi,
Why are you trying to enter an underscore in the numeric entry widget? Is there a use case that you need an underscore with numbers?
Meghan
I am trying to do a validation. If I enter anything except a digit in the numeric widget it should throw an error. I wrote java script for that and If i use the base type as string it will work but when i choose a number it does not work. Since numeric entry widget doesn't allow any other special characters. Why is it allowing underscore?
Java 8 allows underscores in numbers to make them more readable. I'd guess the widget is following suit e.g.
100_000_000 is the same as 100000000
PaiChung
22-Sapphire I
(To:brsmith)
Except that Thingworx itself doesn't process it that way, right now Thingworx will read 1_000 as 1 vs. 1000
Well, it was a guess
