We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I try to use the function of InfoTable Filter , but it always return null. What's the correct way to call the function ?
BTW, infoTable.Find works as expected.
Sean
Hi @seanccc.
Can you advise if there is a reason that you need to use the one that doesn't appear to be working vs. the one that does work? We're taking a look at it but would like to know if you are stalled in your development because of it.
--Sharon
No it's a blocking problem for me , I prefer to try the not working one just because the approach is more concise and straightforward.
Sean
