Starting from a wt part's ufid I want to get the other versions of it.
I thought to use the GetVersionHistory.
Here is the snippet code I found:
var params = {
ufids: undefined /* INFOTABLE */,
dataShape: undefined /* DATASHAPENAME */
};// result: INFOTABLE
var Result = Things["ptc-windchill-demo-thing"].GetVersionHistory(params);
How the ufids infotable have to be build ?
I mean, is it ok an infotable called generically UfidsInfoTable containing only one field where I'll insert the wt part's ufid ?
Thanks and Regards,
