Hello Everyone,
Perviously I was using thingworx version 9.2 and now upgrade to thingworx version 9.6. In 9.2 version using Infotablesector widget but it is missing in version 9.6. So please let me know if there any alternate solution available. Or we can import the same widget in version 9.6.
For reference: Check https://www.ptc.com/en/support/article/CS306868 which states the extension can be found in the ThingWorx-Utilities-Core bundle.
In 9.5 and 9.6 documentation it is still documented: https://support.ptc.com/help/thingworx/platform/r9.6/en/#page/ThingWorx/Help/Mashup_Builder/Widgets/InfotableSelectorWidget.html
Since it is not available in Mashup editor, I recommend to create a case with PTC support for clarification.
There is an unsupported selector widget available here, which you could try. https://github.com/cbadici/thingworx-infotableselector-widget
