Hi,Friends!
When I execute the following code(java -jar thingpredictor.jar server prediction-with-analysis.yml),
I will report a mistake, which can refer to the following attachments.I want to install ThingPredictor7.4.
Who can help me?Looking forward to your reply.
Thanks!
Hi Juanjuan
From the logs it appears that ThingPredictor cannot connect to your ThingWorx server.
Could you check on the same machine where you start ThingPredictor, can you access http://localhost:8080/ThingWorx (it is important to use this exatc url)
if it works:
is the application key correct ?
can you stop the firewall for a test ?
Hope this helps
Kind regards
Christophe
