what will happen if i install thingworx on local computer which is not windows server 12 or 16
Thanks & Regards
Bharathan
@BharathanB You can install ThingWorx 8.3 on a windows 10 pro machine. It will have all the same capabilities as one installed on a windows server 2012 or 2016.
Vibhuti
@BharathanB What is the OS on which you are planning to install Thingworx? And also the Thingworx version?
Vibhuti
On windows 10 pro
Thingworx version 8.3
Vibhuti
I just wanted to follow up with you to see if previous response was helpful for your question?
If so, please indicate the appropriate response as the Accepted Solution for the benefit of other Community members who have the same question.
Vibhuti
