July 15, 2016
Dear Sirs
I installed Thingworx platform 7.1 on Ubuntu 14.04.4 LTS, following your document “Installing ThingWorx 7.1 Version 1.3”.
I would like to submit you the minor changes I made to some instructions. Without these changes I could not set up Tomcat application server. I used Tomcat 8.5.3.
• Page 20; step 19
Instead of instruction
sudo chmod 640 conf/ *,
I used
sudo chmod -R 770 conf/ .
The instruction conf/ * changes the folders at the same level of conf;
the chmod value 640 blocks Tomcat process.
• Page 21, step 25
About keystore file,
instead of value "{$user.home}/8.5.3/.keystore"
I used "conf/.keystore",
because with original instruction resulting path is /usr/share/tomcat/8.5.3/tomcat/8.5.3
instead of
I added also field keyAlias,
with value "tomcat8”,
because in step 23 of page 21 alias parameter was tomcat8,
but default alias of tomcat process was tomcat , instead of tomcat8 .
Thank you for your attention and your suggestions.
Best regards,
Sergio Marino
Sysdev, Torino ITALY
Sergio, thanks for the notes! I'll talk to our documentation team about reviewing the installation steps and pass on your changes/ suggestions.
