Hi
I am trying to Install Thingworx 8.3 in my Local PC without using Virtual machine But i am Getting Certain Errors
Then I installed the Apache Tomcat, ThingworxStorage and ThingworxBackupStorage are not created in Local disk C
While Opening PostgreSQL PgAdmin 3 It displays the Error that the Connecting to database failed
Can anyone guide me to installing Thingworx on my local PC?
Are you running a 64-bit version of Windows 10 as well as a 64-bit version of Java? Please review the
ThingWorx 8.3 System Requirements
The installation instructions for Thingworx 8.3 are here
Also, you may refer to these articles for more information.
https://www.ptc.com/en/support/article?n=CS230085
https://www.ptc.com/en/support/article?n=CS235937
https://www.ptc.com/en/support/article?n=CS226826
If you see any error while installing per the above guide, please provide us logs. You can find ThingWorx and Tomcat logs here:
The location of ThingWorx log files
Vibhuti
Check also this: https://stackoverflow.com/questions/32453451/postgres-installation-the-database-cluster-initialization-failed-postgresql-ve
Thank you,
Raluca Edu
