Integration Runtime ThingWorx SAP parse wrong
bot1q
we have some trouble to use the Thingworx SAPOdataconnector with standard SAP interfaces.
Reason for this is clear, the IR (Integration Runtime) tries to parse the Metadata from XML Resource Section (See Screenshot) with https://******/$Values/$Metadata <- But $Metadata does not exist, cause not every "Resource" is an Odata Service itself.
What can be done is for sure just use the content loader functions ... but than the Integration Runtime is useless.
Does anyone knows a workaround -> request for improvement and support ticket is allready opened.
ps: The online viewer is bad ... if you download the Screenshot you can see what is inside
slangley
(To:slangley)
Hi @bot1q.
Integration Runtime 8.0.12 was released this week.  You can find it by navigating to any ThingWorx Foundation version:
--Sharon
slangley
(To:bot1q)
Hi @bot1q.
A fix for this issue is being released in Integration Runtime 8.0.12.
We'll post another update once it is available for download.
--Sharon
slangley
(To:slangley)
Hi @bot1q.
--Sharon
bot1q
(To:slangley)
Hi, this IR was released after we have request this cause of 2 bugs. One of them was solved ... the other is not possible they say... Please use Thingworx Flow.... Now we have installed flow for 1 month with help of PTC Support and now playing around 2 month with access SAP... So we created our own procedure took us 1.5 hours ... nd tada, we can access SAP. I do not understand why this is so difficult for PTC ...
