Hi all,
I've been working with the Reference Lines feature on the Line Charts recently and while I can label them, I was wondering if it's possible to format and apply different styles to each line to help tell them apart at a glance?
In my use case, the label's being used to show the value that the line is plotted at, so it'd be helpful if I could apply different colours, etc. to each line to give a little more info to them.
I can't see anything in the style properties, but not sure if there's any CSS wizardry or something I'm missing that might help?
Not sure if this helps or not, CSS not my forte and I'm not sure about what elements you can or can not change.
Sorry for the very, very late reply, but thanks for the help! Got pulled about for a bit and this got lost, but that link has been very helpful in both sorting this and a few other things.
