Is it possible to format the reference value of a line chart?
Subodh_Sharma
7-Bedrock
I am working on Chart Bar and my Reference line value does show complete.
Current output value is -
And desired output value is -
Thanks.
u can use number of reference line property from line chart to show the reference value and pass the respective datapoints to reference value fields so that u will able to see reference values in graph
Hi, @Subodh_Sharma  Can you check line chart property NumberOfReferenceLines?
My problem is Reference line value is truncated due to the big length and show on mouse over. I want to show it without mouseover.
Reference value is showing on Chart but it is not showing completely. It shows on mouse hover.
I want to increase the reference value display area.
Hello @Subodh_Sharma
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
