Hi @AP_10343008.
We played around with this a little but were unable to find a solution. Perhaps someone else in the community has found a way to do this.
You can submit a request for this on the ThingWorx Ideas forum, which will allow others to vote for it.
Regards.
--Sharon
I think I've seen this done unfortunately I forget where, but I think ...
If you can dynamically bind a value to the tooltip, you can use an expression to generate it with a "text" + /r (or /n + "text" I think ...
Tried to bind the tooltip fied dynamically, it's working if i am binding it with textfield widget, but as a tooltip message i am not getting it in new line. could you please some other way to do it?
Hi @AP_10343008.
Regards.
--Sharon
