Need a widget which can be used to show a preview of a document(PDF, Image, Excel, etc) in an image form like good does. Is there one in Thingworx?
Thanks and Regards,
Jyothi
Don't think there is anything OOTB like that, you could use a WebFrame widget to display the PDF though as a potential solution. (Browser must be able to display PDF)
Hi @jrajesh
Just wanted to follow up to see if Pai's response answered your question. If so, please Accept Solution for the benefit of the rest of our Community. If not, please advise on current status.
Thanks!
Leigh
