Is there a stream's limit of entries one can add?
fmanniti
9-Granite
Hello, I would like to know an information:
is there a limit of entries I can add to a stream in just one service?
If I want to add one million of entries, for example, there could be any problem?
1 ACCEPTED SOLUTION
CRArko
(To:fmanniti)
Hello.
I'd suggest reading through this article about tuning the stream process in ThingWorx. It's not so much about a hard limit on number of items as it is about total data size in the stream, and how that can affect performance.
The article also describes parameters that can be adjusted to manage stream performance.
This article may also be useful.
Let me know if this is helpful.
-- Craig A.
3 REPLIES 3
CRArko
(To:fmanniti)
Hello.
-- Craig A.
fmanniti
9-Granite
(To:CRArko)
Thank you
fmanniti
9-Granite
(To:CRArko)
So, if I get it right:
maximumBlockSize: Maximum number of queued entries that will be assigned to a single processing thread when flushing to disk
  • ThingWorx default: 2500 entries
would it be correct if I say, for example, that every (let's say) 1000 entries I "wait" for 2 seconds?
Otherwise I don't get what could be the solution.
If I have a huge amount of data (like 1 millions of rows) how can I fill them into the stream
