Is there any option to give to alias name to sql result columns like Target,Actual?
rvuta1
Hi Sushant
Now I have  to add sql service result to a data table as columns names are coming dynamically.
DataTable have fields like "Product Name","Target","Actual".
SQL service result is coming with column names as Target_A,Target_B..etc  on every iteration .
How to map this result with data table object properties?
Raji.
Message was edited by: Sushant Pandey branched from https://community.thingworx.com/message/58830#58830
qngo
(To:rvuta1)
Hi, with the SQL query, you can change the column names with "... Target_A AS Product_Name ..." right ? Or you can change the column name after retrieveing the data with RenameField
var params = {
  t: data/* INFOTABLE */,
  to: "Product Name" /* STRING */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].RenameField(params);
rvuta1
(To:qngo)
I am passing property names of thing dynamically to service "GetNamedPropertyValues" and retrieving their values.
In  your suggestion I have two doubts.
1..As property name is changing every time ,how can I pass "From" filed dynamically.
2.  I didn't find "RenameFiled" service as the service of infotable. how to check that service?
Raji
qngo
(To:rvuta1)
1. Without knowing your whole usecase, I suggest using Localization Table and provide in advance a "translation" of all possible property names. Then retrieve its "translation" with service, for example:
Resources["RuntimeLocalizationFunctions"].GetEffectiveToken({token: undefined /* STRING */})
or
Resources["RuntimeLocalizationFunctions"].GetEffectiveTokenForLanguage({language: undefined /* STRING */, token: undefined /* STRING */})
2. In service zone, you can check it in two ways:
i. Tab Snippets, type RenameField
ii. Tab Entities, type InfoTableFunctions, then RenameField
