Issue ThingWorx Flow CLI
cirver
Hi
I'm learning the development of Thingworx Flow SDK recently,and now I am creating Gmail Authentications.
When I execute the command 'flow test oauth <oauth-name>' ,an error occurred:
command text:
flow test oauth Gmail-GmailOAuth -f C:\twxconnector\test\testOauthData.json -t "Test Gmail Oauth"
nginx log:
fiddler:
refer doc:
http://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/#page/ThingWorx%2FHelp%2FIntegration_Orch...
Thinks
raluca_edu
(To:cirver)
Did you deploy that Gmail Oauth first?
Raluca Edu
cirver
(To:raluca_edu)
Thank you Raluca Edu,but the help document says that it can be tested before deployment.
And it still doesn't work after I deploy it. ---- same error message
In addition,I can't find the section "Configuration for Testing OAuths and Triggers" and the file with the path '.flow\\flow.json'
my home directory:
gnandyala
(To:cirver)
Hi criver,
Can we have a look at your flow.json file
