Hi
I'm learning the development of Thingworx Flow SDK recently,and now I am creating Gmail Authentications.
When I execute the command 'flow test oauth <oauth-name>' ,an error occurred:
command text:
flow test oauth Gmail-GmailOAuth -f C:\twxconnector\test\testOauthData.json -t "Test Gmail Oauth"
nginx log:
fiddler:
refer doc:
Thinks
Did you deploy that Gmail Oauth first?
Raluca Edu
Thank you Raluca Edu,but the help document says that it can be tested before deployment.
And it still doesn't work after I deploy it. ---- same error message
In addition,I can't find the section "Configuration for Testing OAuths and Triggers" and the file with the path '.flow\\flow.json'
my home directory:
Hi criver,
Can we have a look at your flow.json file
