I have Thingworx Trial Edition (Docker)
I need to connect to mysql server, but I can't install Relational Databases Connectors extension due to conflict with PostgresSql
Is there any solution ?
Haven't seen this error before, do you have the screenshot for this error message?
There's also another extension you can use, and you can search for JDBC connector extension in the Market Place.
hi @bakrim just to be sure are you importing the entire Relational Database Connectors zip or just the zip for MySQL?
