It's possible hidden o remove generic properties?
rodbastidas
7-Bedrock
Hi Community!
I'm creating an application for tank measurement, then I'm generating a CSV file with data from a Thing with service GetPropertiesValues, Is there any way to hidden the generic properties and only binding my properties?
Thanks in advance!
PaiChung
22-Sapphire I
(To:rodbastidas)
Ok it ate my code example it seems to not like javascript in this field
but you just create a new service on your Thing
call GetPropertyValues from that service
use RemoveField to drop columns
set your output to result
also you should create a DataShape to match what you want to put out.
PaiChung
22-Sapphire I
(To:rodbastidas)
Create a wrapper service that removes the fields (or assign to a datashape that doesn't have the fields)
Could you please give any example how to do the wrapper service?
PaiChung
22-Sapphire I
(To:rodbastidas)
