I recently had another ticket that got me connected to the java hosted trial but now I am getting this error associated with the ThingName I am creating.
com.thingworx.common.exceptions.GenericHTTPException: Entity ExampleThing_1 does not exist or is not yet associated with a Thing
Here is the line that creates the ThingName.
private static String ThingName = "ExampleThing_1";
What am I doing wrong here?
Well, After a lot of messing around I think I figured out the issue. The guide uses the wrong .java file so it was looking for a thing that doesn't exist. I used the exampleClient.java and it connects no problem. I assume this is the solution.
