we are trying to get the content from the url using POSTJSON service. used the below code:
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: undefined /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: undefined /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: undefined /* STRING */,
url: "https://public-api.wordpress.com/rest/v1/sites/www.davidjmcclelland.com/posts/" /* STRING */,
content: undefined /* JSON */,
timeout: undefined /* NUMBER */,
proxyPort: undefined /* INTEGER */,
password: undefined /* STRING */,
domain: undefined /* STRING */,
username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
But we are getting the error while running the service.
The error is given below :
Error executing service
Wrapped java.net.UnknownHostException: public-api.wordpress.com Cause: public-api.wordpress.com
Aditya Kumar
Please help us with the error
Aditya, what version of ThingWorx are you using? There was a fix released recently on versions 6.5.8, 6.6.3 and 7.0.1 regarding not getting any header information back when using PostJSON; but you still should not be getting the error message you're currently seeing. I tested this out on 6.5.9, and I didn't get any errors.
Hi Ravi,
We are using 6.5.0 version.
Aditya Kumar
Hi Aditya,
I tried your code with TW 6.0. I am not getting any error. But the result of that post is null.
I tried with GetJson(), then I could get the data (nearly 129 posts.)
Thank you.
With B/R,
Praveen.B
Is this a problem of proxy or what, due to which i am getting an error?
Is there a way to bypass the proxy or the host exception?
Aditya
You would need to use GetJSON to get the contents. Are you getting an error when using that as well?
I had set a Proxy server on my server temporarily to download applications. Disabling the proxy does not clear the Windows environment variable HTTP_PROXY. I had to delete the Environment variable to bypass the proxy errors (Unkown host because my REST server was not on a node known to the proxy server)
