I need to get the timestamp of tags updated in kepware to Thingworx.
Using GetPropertyTime() we can only get the property update time in Thingworx rather than the timestamp of Kepware. Is there any way to get values directly instead of running GetPropertyTime()?
Hello Yedukrishnan,
Thank you for reaching out on the ThingWorx Developer Community. I do apologize for the delay in reply.
Were you able to find a solution for this matter?
I do not believe it is possible to get the tag update time in Kepware into ThingWorx.
Tyler Misner
ThingWorx Technical Support Engineer
