Software versions: TWX 9.1.14, MFG apps 9.1.1
Hello all,
My team and I have successfully set up an Active Directory Directory Service (ADDS), so that users log in with their AD credentials, over an LDAPS connection.
We also need to validate a second LDAP user, without logging out and back in. We've tried using the TestConnection Service, but always receive the result of "Unable to decrypt password". See code example below, where we pull all of our inputs from the (still working) ActiveDirectoryDirectoryService:
let table = DirectoryServices["ADDS1"].GetConfigurationTable({
tableName: "Connection" /* STRING */
result = DirectoryServices["ADDS1"].TestConnection({
server: table.server /* STRING */,
password: table.adminPassword/* STRING */,
protocol: table.protocol /* STRING */,
port: table.port /* INTEGER */,
userName: table.adminPrincipal /* STRING */
How do we encrypt the password so that the LDAP server is able to recognize it? The ADDS is clearly able to do so when using the "Test Connection" button (verified by checking the browser devtools, seeing the encrypted password in the params to the Service call), so how do we tap into that? We don't need the second user to do anything more than validate their credentials in this scenario.
Luckily, there's a support article exactly about this issue: https://www.ptc.com/en/support/article/CS357282
It's the first hit if you search on support portal for "TestConnection ldap".
Hope it helps - please let us know.
Somehow, I missed this page in all the searching I did. Thanks!
For posterity, here is the now-working snippet:
let ePass = encryptPropertyValue(table.adminPassword);
password: ePass /* STRING */,
