LOAD JSON/CSV FILE IN THINGWORX
mvolanti
8-Gravel
Hello everyone!!
I'm trying to create a demo having data in csv(or json) format.
I would like to import data's file in the composer, parse it and see data in a mashup with a grid.
Also i would like to create a stream that show me (in the meshup) the parameter's trend.
I created a thing with a repository template (because the file is in C:/ThingworxStorage/repository) but when i try the service loadJSON anything appeare to me.
Can anyone help me??
Thank's!!
keriw
(To:mvolanti)
you need to hit the save button for the service after creating it before you can hit the execute, that's the classic error you see, if you haven't done that.
6 REPLIES 6
keriw
(To:mvolanti)
Maurizio,
Here is an example of pulling data from a csv file stored in a repository and then outputting it as an infotable in a service.
var params = {
  path: "RPTM.csv" /* STRING */,
  columnMappings: "Location;StartTime;EndTime;ProductCode;CasesProduced;PerHourCWS;CWS;Efficiency"/* STRING */,
  hasHeader: true /* BOOLEAN */,
  longitudeField: undefined /* NUMBER */,
  dateFormat: undefined /* STRING */,
  fileRepository: "RPTMFileRepository"/* THINGNAME */,
  latitudeField: undefined /* NUMBER */,
  fieldDelimiter: "," /* STRING */,
  stringDelimiter: "\"" /* STRING */,
  dataShape: "RPTMImport" /* DATASHAPENAME */
// result: INFOTABLE
var rptmData = Resources["CSVParserFunctions"].ReadCSVFile(params);
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "RPTM"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(RPTM)
var modifiedData = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
//translating the date fields in csv to date fields in ThingWorx
for each (var row in rptmData.rows) {
   var startTime = new Date(row.StartTime);
   var endTime = new Date(row.EndTime);
   row.StartTime = startTime;
   row.EndTime = endTime;
    modifiedData.AddRow({
        StartTime: startTime,
        EndTime: endTime,
        ProductCode: row.ProductCode,
        CasesProduced: row.CasesProduced,
        PerHourCWS: row.PerHourCWS,
        CWS: row.CWS,
        Efficiency: row.Efficiency,
        Baseline: 100.00
result = modifiedData;
Keri
mvolanti
8-Gravel
(To:keriw)
Thank's Kery!
I create a service with your script modificate with my name's file and called it GetDataCSV but when i test the servite  appear:
Error executing service
Invalid service name: GetDataCSV
I try to change name service but the error it's the same.
Have you got any idea??
Thank's very much!!
keriw
(To:mvolanti)
mvolanti
8-Gravel
(To:keriw)
thank's very much!
now the problem is:
Wrapped java.lang.Exception: Unable To Convert From java.lang.String to NUMBER Cause: Unable To Convert From java.lang.String to NUMBER
keriw
(To:mvolanti)
what does your data look like, it sounds like it thinks that there is a value in your number field that is coming across as a string
nkhose
(To:mvolanti)
