I have a datetimepicker widget on a mashup (TWX 8.4.1), and I'd like to limit the available range that a user can choose from. For example, my user should only be able to choose a calendar date within the past 7 days. By default, it seems that the widget has no time limits.
Anyone done this before?
You may look into custom java widget development or modify the existing one to accomodate your needs.
Thank you - we will start customizing then.
