while consuming or exposing the REST APIs in Thingworx, are there any limitations or constraints like rate limit, data limit etc?
Hi @CS_11755321 Look at the below reference help center link for the rest API in ThingWorx, can you explain your use case for more clarification of your doubts?
Hi @CS_11755321,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
