Axeda Hackers!
Does anybody know if there are limitations on the number of AssetGroups and UserGroups in Axeda?
We are planning to assign every user its own UserGroup which contains a dedicated AssetGroup for visibility reasons.
Would this work out for thousands of users?
Thanks for any comment,
Klaus
hi Nikolaus
Few questions:
Maciej
Hi Maciej,
we use Regions/Orgs/Locs for our big customers, having hundreds of devices.
For our small customers (only a handful of devices, but thousands of different users/companies) we need to create a "self-service" approach where a customer can do a self-sign-up and can register for his devices by using special reg-keys.
But this means that every user or small company needs his own usergroup where an assetgroup (containing only his devices) controls visibility. The concept is already there and successfully tested.
We use SunONE LDAP right now, but will have migrate to internal user DB for secondary users as LDAP-support is not available anymore with 6.6 and newer So we will end up in the Axeda DB with these thousands of usergroups/assetgroups ...
Klaus
Did you explore the possibility of using Delegated (User) Administration (DA) for your external users?
DA is core Axeda capability that might be of use in your scenario.
We are indeed using Delegated Admin Units, but we found that we can only handle our larger customers via this approach. Small customers (thousands of them) would mean thousands of DA units and we are really not sure if this would work - anyhow also this approach would need thousands of asset groups...
LDAP is still supported.
6.6 Support Matrix Portal URL: https://na2.salesforce.com/01540000000kzTP
The 6.8 Support Matrix will be finalized once released to self-hosted customers.
Chris,
LDAP is still supported, but not anymore for Delegated Admin Units (as secondary user store) since 6.6 ...
Klaus
