Loaded 'validaton.properties' properties file java.lang.Exception: Unable to initialize and start system:
kanagaraj2007
2-Explorer
Hi Team,
We are planning to Test the PTC Navigate 1.4 Features.
We have installed the below Versions of Thingworx 7.3
Windows Server 2008 R2 SP1
Apache Tomcat 8.0.38
java 8u92
After Deploying the Thingworx File, getting the below Error, While Navigate to http://localhost:8080/Thingworx getting '
HTTP Status 401 - Could not handle request'
Loaded 'ESAPI.properties' properties file
Attempting to load validation.properties via file I/O.
Attempting to load validation.properties as resource file via file I/O.
Found in 'org.owasp.esapi.resources' directory: C:\ThingworxStorage\esapi\valida
tion.properties
Loaded 'validation.properties' properties file
java.lang.Exception: Unable to initialize and start system: Connections could no
t be acquired from the underlying database!
        at com.thingworx.system.ThingWorxServer.loadModel(ThingWorxServer.java:4
58)
        at com.thingworx.system.ThingWorxServer.doHA(ThingWorxServer.java:184)
        at com.thingworx.system.ThingWorxBootstrapper.contextInitialized(ThingWo
rxBootstrapper.java:132)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:4853)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContex
t.java:5314)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:725)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:70
1)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:940)
        at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:
1816)
        at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
        at java.util.concurrent.FutureTask.run(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
        at java.lang.Thread.run(Unknown Source)
*** CRITICAL ERROR ON STARTUP: Unable to initialize and start system: Connection
s could not be acquired from the underlying database!
*** Web Application STATE is being set to ERROR! ***
Kanagaraj, which DB are you using as persistence provider? Is this a fresh installation? As noted in the log whatever persistence provider you are using is not reachable.
Hi Sushant,
This is a Fresh Installation. I didn't created a DB and Schema, after Creating I am able to login to Thingworx Application.
Thanks a lot.
Thanks for confirming Kanagaraj.
