Localization token retrieval
KT_10107318
8-Gravel
Hi all, is there any way to retrieve the token name using the token values
There are multiple entry for token name which has same token value. For
 example ui.testpassed= test passed , also test_passed = test passed. Need to clean up duplicate
Thanks in advance
Not directly.. but you try workaround by...
  • Get all token names and values
  • Iterate or over the tokens
  • Or do aggregate with group by token values
let allTokens = LocalizationTables["<localization table>"].GetTokens();
let params = {
	t: allTokens /* INFOTABLE */,
	columns: 'value' /* STRING */,
	aggregates: 'COUNT' /* STRING */,
	groupByColumns: 'value' /* STRING */
let result = Resources["InfoTableFunctions"].Aggregate(params);
1 REPLY 1
let params = {
