is it possible to use persistent broker sessions with the thingworx MQTT extension? So can i set the cleansession flag to false and set a session ID like described e.g. here:
http://www.hivemq.com/blog/mqtt-essentials-part-7-persistent-session-queuing-messages
Push
Hi Nicolas, i think currently it may not be supported/provided with the open source Mosquito used by the extension. Not sure if someone else here have different info on this topic.
I also want to use a persistant (non clean session) for MQTT and dont find it in the configuration window. Is it still not implemented?
BR
