Hello everyone,
I am using MQTT extension in Thingworx and I have the problem lately that I don't get or see the configuration tab in any of the entities that is using one of the extension's templates. I updated the extension to the latest version which is 3.0.1 and I tried different things in the permission but none of them worked. Any idea how to solve the problem?
Hi @MB_10396356
I'm able to see Configuration Tab in my Thingworx Instance
Try to upgrade to the latest version 3.1.0 and restart Thingworx instance (including DB) once
/VR
Hi @Velkumar ,
thank you for the response!
Actually It is the MQTT_Extension version 3.1.0 that I am using and Thingworx 9.2.8.
I start the TWX from the tomcat directly, how would you restart it with the DB?
Best regards
Hi @MB_10396356
It works with 9.2 also
To restart
Postgres - How to Restart PostgreSQL Server on Windows - CommandPrompt Inc.
MS SQL - Start, stop, pause, resume, and restart SQL Server services - SQL Server | Microsoft Learn
/VR
Hi @Velkumar ,
I tried your suggestion but did not work..
when I create a thing template that uses the MQTT connection template it has the configuration tab but when I create a Thing that uses the mqtt connection template, the tab does not appear.
I looked into the permissions but none of the changes I did helped..
any further ideas?
