Relative to post, Can you provide more details on how to make it work? I have a DataShape and made on of the field to a primary key and that primary key is assigned to ID field of tree widget. But still when I refresh (refresh event calls the service that returns InfoTable which is set to the grid widget data), I still see focus lost on a previously selected item.
I think that with tree widget we are out-of-luck of the PK trick, it won't maintain the selected item, I did try tricking the system a while back (two years ago - with TW 6.5) and I wasn't able to do it.
Maybe you can test marketplace Advanced Grid widget (which supports Tree view) and see if it maintains selected item after a refresh (please update here if you check it, as there's more people interested).
Just my two cents / experience,
Carles.
Hi @vpinisetti.
If the response provided by Carles answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
