Mapping multiple service and Thing to Single mashup
ishrivastava-2
Can anyone help  to map multiple service or multiple thing to a single widget.As if i know we can map one service to a single widget at a time.I want to pass data from multiple user to a single widget.Is there any way to do that.
The best thing to do is create a helper thing and then create a service there which updates all of the things you'd like to be updated by your widget. Then you can just bind to one service on the mashup. There is some documentation here which defines the best practice for something similar to this: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS242572&lang=en_US
Hope this helps!
Tori
