Hi Folks,
I have used a boolean Mashup parameter between Main mashup and navigation modal popup and popup should return a boolean value(true/false) on popup close which is not happening. I also tried to used default value(true) of mashup parameter but thats also not getting passed to main mashup.
I can observe this issue in multiple Mashups wherever Mashup parameters are used for Modal popup.
Kindly suggest some suggestions to fix this?
I am using Thingworx version 8.5.6b110
Are you setting the boolean value, before you execute the pop-up close?
you can always make the parameter visible temporarily on both using check boxes and see if the value is being passed back and forth or not.
