Mashup Size Query
MA8731174
Mashup Size Query
Dear Community,
       We have changed our thingworx mashup version from 9.1 to 9.3 and even though everything is same the size of the mashup looks different. In version 9.3 it appeared as zoomed In a bit. If i do Ctrl - then the whole mashup looks small but everything the fontsize of the entries gets also small. So am i missing something regarding the size? anyone has an idea about it.
Thank you
Hi @MA8731174 ,
Check first the style configuration of the grid and all the UI elements that are used in the page. It looks like the fonts at least are bigger in the 9.3 version.
That aside, the comparison is not exactly apple-to-apple, because in the 9.3 screnshot there's a large header, not present in the 9.1 screenshot.
PEHOWE
(To:MA8731174)
@MA8731174 , When you upgraded from 9.1 to 9.3 there are a number of changes which took place in the UI.  If a Mashup is displayed at runtime it should look the same in ThingWorx 9.1 as in ThingWorx 9.3. If you open a Mashup in ThingWorx 9.3 Composer some upgrade take place, you will also be asked to allow conversation to the new widgets. These conversations can not be undone.
The action of opening the Mashup in Composer starts the conversation process.
Do you know if the mashup which has changed was opened in composer after upgrade?
It will then look different.
HTH
Pehowe
