Can anyone help me where can i find the Mashup widgets codes.
The source code of standard mashup widgets is not available. Instead PTC provides a Web Component SDK, so that you can build your own.
/ Constantine
Hi @CS_11755321,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
