When mashup loaded from thingworx composer we get the mashup toolbar but when i am loading the same mashup directly from the url, this toolbar is not loading.
Any idea why is this error?
Image for the said toolbar is attached for reference.)
This toolbar is added automatically cause you have an additionall parameter in url
Thingworx/Runtime/index-jq3.html#mashup=MyMashup&__fromBuilder=7db28934-1591-484f-a185-52667ef18838
If you will remove it and refresh the page (ctrl + F5), toolbar will disapear.
Value of this param is generated automatically, but I believe you can define your own and it should work.
Best,
Adam
