Hello! I've been struggling with a persistent problem of thingworx not updating images when I make a change to a graphic and use the "change" button under graphic properties. I always seem to get the orignal graphic uploaded on preview. Furthermore, I can't seem to just delete that graphic, I have to delete and then name the new graphic something different or else it will load the old graphic again. Any tips?
This could be a caching issue. Not sure if there is an easy way to solve this, but a reload should show the proper image.
