Hello
I have a menu into a Master in order to navigate into Mashups.
It works fine when I'm adminsitrator but it is not displayed when I am a user.
I found some topics & followed them without succes :
I gave access (visibility , run time) to the user group (& associated Organization) for menus, masters, System/SubSystem , etc ... but no menu displayed and nothing in application logs for Authorization error.
All other services are working fine for this user after given such access, only menu display is a problem
Thanks for ideas !
Hello
I found the solution by adding the group in "Group Association"
there is a bug not fixed since 7.2 :
Hope it is fixed in 8 ?
Pascal
Hello
Pascal
