Hello all,
We are running microserver on windows machine. We have established connection with thingworx but we are not able to see properties created in microserver.
Log:
[INFO ] 2018-07-19 07:23:40,305 SystemPerformance: Attempting to GetPropertySubscriptions from server failed. code: 500, result:
[INFO ] 2018-07-19 07:23:40,415 SystemPerformance: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2018-07-19 07:23:40,426 SystemPerformance: EMS is available: true, online: true
[INFO ] 2018-07-19 07:23:40,426 SystemPerformance: Attempting to GetPropertySubscriptions from server failed. code: 500, result:
[INFO ] 2018-07-19 07:23:42,548 SystemPerformance: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2018-07-19 07:23:42,556 SystemPerformance: EMS is available: true, online: true
[WARN ] 2018-07-19 07:23:42,556 thingworx.server: Could not set properties on server. code: 500, resp:
[INFO ] 2018-07-19 07:23:44,150 SystemPerformance: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2018-07-19 07:23:44,160 SystemPerformance: EMS is available: true, online: true
[WARN ] 2018-07-19 07:23:44,160 thingworx.server: Could not set properties on server. code: 500, resp:
[INFO ] 2018-07-19 07:23:46,179 SystemPerformance: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2018-07-19 07:23:46,186 SystemPerformance: EMS is available: true, online: true
[WARN ] 2018-07-19 07:23:46,186 thingworx.server: Could not set properties on server. code: 500, resp:
[INFO ] 2018-07-19 07:23:48,203 SystemPerformance: Error occured while accessing EMS. Checking isConnected.
[INFO ] 2018-07-19 07:23:48,209 SystemPerformance: EMS is available: true, online: true
[WARN ] 2018-07-19 07:23:48,209 thingworx.server: Could not set properties on server. code: 500, resp:
