Hi All,
I need to store inside thingworx the information taked from db table or csv file (the structure of this data are 4 columns for 100 rows in the first step, but the numbers of the rows are growing).
These data will be accessed by services that use a input parameter to return only one information (the input parametri will identfy onli one row of this data).
Please, can you help about the following information :
1) what Entity I used to store the data on thingworx?
2) how I can to develop a service to take information form this entity?
3) how I use to devlop service for add or remove data on this entity ?
Many Thanks
BR
Dimitri
Dimitri, there are different methods to do this. You would essentially need to create a database connection (if you have a DB) or use something like the CSV parser extension to load the csv data into ThingWorx. The database connection can be done in numerous ways as well; depending on your database, through a JDBC extension or through ADO. I would recommend going through the Connecting to External Data Sources tutorial section.
If you have this data in a database already, you can use the method that Aanjan suggests.
If you want it in Thingworx, in Thingworx there are DataTables, they use a DataShape that have a primary key defined for them.
They basically mimic a relational database table. It also comes with all sorts of built-in services to do Add/Query/Delete etc.
