So I was following the tutorial steps about how to connect kepware server to thingworx foundation.
Here is the link: https://developer.thingworx.com/en/resources/learning-paths/connect-and-monitor-plant-equipment/connect-kepware-server-thingworx-guide/visualize-data.
When I reached this last part of step 6: Visualise the data, I opened the view mashup in thingworx and this appeared. (the following image). It's empty and did not display any data and I have already confirmed the test connection to IndConn as they mentioned
Can someone help me out please?
1. What version of ThingWorx and Kepware are you using?
2. You can open a support "Case", here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
