I am stuck at configuring charts as there is no drop-down list for my LabelField.
Link to the guide: https://developer.thingworx.com/en/resources/guides/display-data-charts/ddc-configure-charts
What mine shows
What is supposed to be shown
What I meant was the image displayed under Connections tab. Do you see something similar after clicking Label Chart?
Upon clicking the Label chart do you see the Connections as is shown for the Pie Chart in Step 3 of the guide. Ideally, you should see similar connections upon completing step 4.
Nope, I cannot see any drop-down list in my LabelField despit following the guide.
Yup, I see the same connections after binding the data to the widget.
It worked after I deleted the widget and inserted it into the mashup again, thanks for the help anyway!
