Need help with Date Properties and Appkey permissions
GV_11098078
6-Contributor
I have a mashup where im using the service GetProperties, in the Data Properties section i have the checkbox "Automatically update values when new values are available." selected.
When I run my mashup passing the appkey through the link that access the mashup when I use my admin user it run properly the Data Propertie I checked, but when I change the appkey to my viewer user it doesnt work properly.
I have given permission to the user in the Run Time permissions i checked every box as Allow, and in the visibility I inserted the user organization, for both the mashup and thing. Also in thr User Profile the option for Subsystem is also checked.
I dont know what am I doing wrong and why when I change the appkey to my user that's not an admin the "Automatically update values when new values are available." doesnt work properly in my mashup. Any suggestions?
Hi @GV_11098078  there you need to provide some additional permissions to entity Browser Gateway.
Here is the code you need to execute it with your usergroup.
// VISIBILITY PERMISSIONS
let projectVisibilityPermissionEntities = [
    // ThingTemplates["BrowserGateway"],
    Resources["AlertFunctions"],
    Resources["EntityServices"],
    Subsystems["PlatformSubsystem"],
    Subsystems["AlertProcessingSubsystem"],
    Subsystems["EventProcessingSubsystem"],
    Resources["RuntimeLocalizationFunctions"],
    Resources["CurrentSessionInfo"],
    Resources["InfoTableFunctions"],
    StyleThemes["PTC Convergence Theme"],
    LocalizationTables["de"],
projectVisibilityPermissionEntities.forEach((entity) => {
    entity.AddVisibilityPermission({
        principal: "write your name of organization here",
        principalType: "Organization"
// RUNTIME PERMISSIONS
// let c = {
//     Resources["EntityServices"]: ["GetClientApplicationKey"]
//     ThingTemplates["BrowserGateway"]: ["*"]
// EntitiyServices: Visibility +  GetClientApplicationKey service
// BrowserGateway Instances RunTime: All Properties and services
Resources["EntityServices"].AddRunTimePermission({
	allow: true,
	principal: "write your usergroup here",
	principalType: "Group",
	resource: "GetClientApplicationKey",
	type: "ServiceInvoke"
Resources["RuntimeLocalizationFunctions"].AddRunTimePermission({
	allow: true,
	resource: "GetEffectiveToken",
ThingTemplates["BrowserGateway"].SetRunTimePermissionsAsJSON({
    permissions: getRuntimePermissionsJson("Users")
ThingTemplates["BrowserGateway"].SetInstanceRunTimePermissionsAsJSON({
Subsystems["EventProcessingSubsystem"].SetRunTimePermissionsAsJSON({
Subsystems["EventProcessingSubsystem"].SetInstanceRunTimePermissionsAsJSON({
function getRuntimePermissionsJson(groupName) {
    return {
        "permissions": [
                "resourceName": "*",
                "EventSubscribe": [
                        "isPermitted": true,
                        "name": groupName,
                        "type": "Group"
                "PropertyWrite": [
                        "name": groupName,
                        "type": "Group"
                "PropertyRead": [
                        "name": groupName,
                        "type": "Group"
                "ServiceInvoke": [
                        "name": groupName,
                        "type": "Group"
                "EventInvoke": [
                        "name": groupName,
                        "type": "Group"
There is this article for the GetProperties permissions: https://www.ptc.com/en/support/article/CS322093?as=1
It's a little tricky as in the background it uses the BrowserGateway-ThingTemplate which needs permissions as well.
// let c = {
	allow: true,
	allow: true,
    return {
        "permissions": [
                "EventSubscribe": [
                        "name": groupName,
                        "type": "Group"
                "PropertyWrite": [
                        "name": groupName,
                        "type": "Group"
                "PropertyRead": [
                        "name": groupName,
                        "type": "Group"
                "ServiceInvoke": [
                        "name": groupName,
                        "type": "Group"
                "EventInvoke": [
                        "name": groupName,
                        "type": "Group"
Hi @GV_11098078,
Anurag
