Hello @DK_9178998 ,
I have talked with the Subject Matter Experts, the feature you are looking for was not included in the Collection Widget design.
If you feel this is a necessary feature put a post in the Idea's form.
There is currently no support for the feature you had in previous version of the collection widget.
Pehowe
Hello @DK_9178998 ,
In researching the issue you describe. Have you reviewed Article - CS378761 - In Thingworx Collection widget cell mashups are reloaded when data is refreshed unless property PlaysIntroAnimation is enabled.
It describes the same issue you describe. It also identifies this as expected behavior. They also discuss a work around.
Do you have this property enabled?
If this does not address your issue please provide both version you have used. I will see if there is any other information.
Pehowe
Hello @DK_9178998 ,
Pehowe
